combine motor in a c
Pat-CT
10-09-2007 04:18:55
how hard is it to find a combine motor that will fity into a c ?
Bill46
10-09-2007 10:24:56
 Re: combine motor in a c in reply to Pat-CT, 10-09-2007 04:18:55
I put a 153 in a Super A...darn thing is dangerous. Need to turn the governor down.
Hardest thing about a combine motor is there is no hole in the crankshaft for a pilot bushing.
I got around that using a 300U bearing set up and a 404 clutch and pressure plate.
Look for a link here on 153 in a super A or something like that...there is a lot to do.
C should be about the same.
Good luck.
Trent M
10-09-2007 08:04:01
I don't know but someone has done it. There is one on photo ads right now in TN.
Link
fixerupper
10-09-2007 06:02:21
I'm no expert by any means, but I believe the U2 power unit is the same cu. inch engine as the one in the C. Good luck with the search. Jim
Nat 2
10-09-2007 04:52:08
Probably a lot harder than finding a C or Super C engines. There were a lot more Cs and Super Cs than combines, and the combines tended to get scrapped way more frequently than the tractors. Don't get me wrong, they're still some out there, but if you need it NOW, you'll be able to find a tractor engine a lot easier and quicker.
