Neblinc
Mike CA
10-10-2007 15:11:07
Randy,
You pulled what sounds like a stock radiator instalation set up from your '43 H. Could you snap a photo of all the hardware laid out? As for spring size, can you compare them to the fuel tank springs? I will have extra fuel tank springs, but OEM doesn't sell an H radiator mounting kit.
I want to make sure I get it right so the radiator sits how it should, and I can get the sheet metal back on it correctly.
Thanks in advance!
johnfleming
10-11-2007 13:13:54
 Re: Neblinc in reply to Mike CA, 10-10-2007 15:11:07
Way make shims when you can use automotive alignment shims may 2 cents john
Mike CA
10-11-2007 09:08:57
Ahh, very good point I didn't consider. Thanks.
Mike CA
10-11-2007 08:03:31
Am I wrong to think that the "correct" pads from OEM will preclude me from having to shim the radiator?
What am I shooting for as far as placement, exactly? I'm assuming I want it centered at the grill hole, and at the correct height so the grill sets right on the frame. Right?
RustyFarmall
10-11-2007 09:08:12
 Re: Neblinc in reply to Mike CA, 10-11-2007 08:03:31
Mike, the biggest issue with the exact location of the radiator is getting that steering shaft to go through the hole in the radiator and NOT rub on anything when you are done. If you accomplish that, everything else will be right.
glennster
10-11-2007 07:57:01
mike, a hardware store should have an assortment of springs, farm and fleet also has a good selection. finding something close to your spring shouldnt be a problem, i usually get them a little long and then cut them to length. if you need to shim up the radiator, get an old mudflap from a semi truck and use a hole saw to cut out some disks to use as spacers. cut a slot from the outside of the shim to the center so you can slide them between the radiator and the bolster to line it up.
Mike CA
10-11-2007 07:48:56
Well, like I said, my concern is more about the fit of the sheet metal. So, I think as long as I get the correct pad in there, and don't cinch it down wrong, I will be ok.
neblinc
10-11-2007 07:42:55
Well it's not like you are going to be bouncing around in a farm field for days on end third party image
So I would say you would be safe in putting it back the way it was, don't think the correct police will be looking there third party image
Randy
Mike CA
10-11-2007 07:26:43
That makes me believe that the radiator will be bouncing all over the place.
Since I haven't found a source for new radiator springs, and since one of my radiator studs isn't a stock size (it's smaller) I was just planning on using an old fuel tank spring, if any spring at all. There was no spring when I took it off, and it spent years like that.
To me it would make sense to sandwich the spring in between two bigger washers. It I don't put one behnd the castle nut, I would worry about it popping into the spring.
neblinc
10-11-2007 06:49:49
If I remember correctly, the rubber pad goes between the radiator and frame. The studs should have a hole for the cotter pin.
From underneath, flat washer goes on first, then spring, then castle nut and cotter pin.
Randy
neblinc
10-11-2007 05:29:51
I will see if I can get some kind of pic for you Mike, all my parts are stacked on my metal shelving and is probably buried.
Randy
RustyFarmall
10-11-2007 04:44:14
Mike, I've got the rubber mounting pads, they are the same as the fuel tank pads. I'll look in the parts catalog and see if the springs are the same.
RustyFarmall
10-11-2007 06:12:02
 Re: Neblinc in reply to RustyFarmall, 10-11-2007 04:44:14
Radiator hold down spring part number 48826D serial# 501 to 122291.
Part number 67205D serial# 122292 and up.
Fuel tank hold down spring part number 51124D.
You can see that the part numbers are not the same, but that does not necessarilly mean that one could not be substituded for the other. Don't know for sure.
