How wide to plow?
Butch WI
10-10-2007 18:38:02
Hello all,
I hope to sink my recently aquired 311 3 - 14's plow into the ground this weekend using my 460 U. It has the power adjust wheels. I was wondering how wide I should put the stance to accomodat effective plowing. Can anyone help me out? I don't have a manual for the plow I wish I did.
TIA
Butch
Dave Sherburne NY
10-11-2007 10:07:05
 Re: How wide to plow? in reply to Butch WI, 10-10-2007 18:38:02
Operation care and repair of farm machinery book says 25 1/2" from center of tractor to inside of right rear wheel.
Hugh MacKay
10-11-2007 02:30:42
Butch: Len is basically correct, although you do have a bit of leway. Plows pull the easiest if the center line of plow draft is centered on tractor, quite important if your plowing with 15 hp or less per bottom.
LenND
10-10-2007 19:52:47
With a 3-14 plow I think you will probably need to have your wheels set in as far as they go. The 3-14's is 42 inches wide so to keep your wheel in the furrow the inside of the tire should be about twenty one inches from center.
wolfman
10-10-2007 19:26:07
Set your right wheel tread so that inside of sidewall is about 14 in to the right of the first bottom's shin. (or 14 and 3/4 from where first coulter cuts).
Dave H (MI)
10-10-2007 19:07:24
When I do it with a plow that I have no info on I set it up so my inside tire would ride in the furrow and the first landslide behind it dumps it's load over my tire track in that furrow...if that makes sense. Doesn't much matter how many bottoms.
