H Front Cover
gauger
10-11-2007 05:01:24
There is a gasket on each side of the front crankcase plate on the H. Plate to block and front cover to plate. Is sealant required??
Steven f/AZ
10-11-2007 07:51:44
 Re: H Front Cover in reply to gauger, 10-11-2007 05:01:24
When I put my H back together I decided to just clean everything up really good and make sure nothing was warped or gouged. Big mistake. I have oil leaks all over the place.
The tractors I"ve put together with a thin coat of RTV on both sides of the gasket haven"t leaked yet. The high-tack spray works well, too.
glennster
10-11-2007 05:40:41
i use permatex hi tack aerosol gasket sealer on them. spray both sides of the gasket. a lot less chance of excess material dripping inside the motor as with a tube of silicone sealer.
