2pt hitch swap
r4etired
10-11-2007 06:44:32
Will the 2pt from a 460 rowcrop fit a 450 rowcrop.
Nat 2
10-11-2007 08:29:58
 Re: 2pt hitch swap in reply to r4etired, 10-11-2007 06:44:32
No, but it will easily fit a 350.
the tractor vet
10-11-2007 07:48:13
No ,the rearend is narrower on a 460 then a 450 ya can squeek by with one off a 350 .
georgeky
10-11-2007 08:08:52
 Re: 2pt hitch swap in reply to the tractor vet, 10-11-2007 07:48:13
350 is narrower than a 450 too.
the tractor vet
10-11-2007 08:36:01
 Re: 2pt hitch swap in reply to georgeky, 10-11-2007 08:08:52
I know that MTA thru 560 are the same 300-460 same same.
georgeky
10-11-2007 09:08:00
 Re: 2pt hitch swap in reply to the tractor vet, 10-11-2007 08:36:01
Maybe I misunderstood you. I think he was wanting to put one off a 460 onto a 450, in which case he can't get by with one from a 350.
ejr-IA
10-11-2007 07:39:24
Theirs a difference between the side mounting plates that bolt to the rear end houseing.I think if you had a pair of plates off a 450 or 560 the rest would work.
