300 Utility Gas Tank Removal
Mike Indiana
10-11-2007 07:55:35
What are the steps to remove the gas tank from a 300 Utility tractor? Any help will be welcomed.
Janicholson
10-11-2007 11:45:08
 Re: 300 Utility Gas Tank Removal in reply to Mike Indiana, 10-11-2007 07:55:35
Remove fuel by drailing at the sedement bowl.
Remove side and center sheet metal.
Remove all lines and attahced brackets.
Remove the Mount bolts and the sedement bowl (prevents breaking it off).
Lift and remove (do not stress test any remaining lines or wires, they will break.
I cannot remember if aircleaner parts need to come off, but it is possible. JimN
Mike Indiana
10-11-2007 11:51:37
 Re: 300 Utility Gas Tank Removal in reply to Janicholson, 10-11-2007 11:45:08
Do you have to remove the metal housing that holds all of the guages?
Janicholson
10-11-2007 12:04:20
 Re: 300 Utility Gas Tank Removal in reply to Mike Indiana, 10-11-2007 11:51:37
On our 350 we did not, but I cannot guarantee the result on a 300. JimN
