H intake pipe
Scott Rukke
10-11-2007 08:26:11
Will a carburetor intake pipe from an M fit an H?
neblinc
10-11-2007 11:54:13
 Re: H intake pipe in reply to Scott Rukke, 10-11-2007 08:26:11
One on ebay right now.
ebay
Janicholson
10-11-2007 09:14:33
Getting a piece bent at a muffler shop, and fitting brazed in is pretty cheap/fast. JimN
RustyFarmall
10-11-2007 08:59:29
No. Not without doing a few modifications, and then the diameter would still be too large unless you are using an M carburetor. There is also the issue of the size of the fitting where the tube attaches to the air cleaner, which can be modified also if you are determined enough to make it work.
