SM IH
Jeff Elliott
10-11-2007 09:32:05
I have a problem identifying my tractor. The serial# 48332 CJ and model all it says is SM.
Thats all the info it gives besides max. Idle speed 160 RPM. Can anyone ID this tractor for me? I took the Head to get it rebuilt and need the right gaskets and considering bearings and new rigs with a hone job. Thanks for any info Jeff.
sammy the RED
10-11-2007 21:14:14
 Re: SM IH in reply to Jeff Elliott, 10-11-2007 09:32:05
"Jeff Elliott" [quote:9f8f43a1bb] Can anyone ID this tractor for me?
[/quote:9f8f43a1bb]
Sounds like you have a ---> International Harvester - McCormick - Farmall - Super M made in 1953. third party image
Jeff Elliott
10-11-2007 16:10:55
Yes the battery is under the seat. As far as the pump, I"m not sure what your talking about. Please explain. And again I appreicate all the information.
Jeff.
Nat 2
10-12-2007 05:09:57
 Re: SM IH in reply to Jeff Elliott, 10-11-2007 16:10:55
The distributor is on the right side of the engine. Look in front of the distributor on your tractor. If there is a hydraulic pump there, it has live hydraulics. If there is just a plain casting there, it does NOT have live hydraulics. Both configurations were available in 1953.
Live hydraulics means the hydraulics work when you have the clutch pedal pushed in. It's a desirable feature.
Janicholson
10-11-2007 09:48:36
1953 Super M. The J at the end means it has a rockford clutch. (almost all replacement clutches are Rockford, so it means notheing important. I do not know what the C means.
If it has a live hydrsulic pump in front of the distributor, and battery under the seat, it is a stage 2 SM. JimN
Wardner
10-11-2007 12:13:10
 Re: SM IH in reply to Janicholson, 10-11-2007 09:48:36
C = LP gas option in my M-SM parts book.
Seeing that propane wasn't mentioned originally, I presume the tractor was retro fitted with gasoline parts.
Janicholson
10-11-2007 12:19:59
 Re: SM IH in reply to Wardner, 10-11-2007 12:13:10
Thanks, JimN
Jeff Elliott
10-11-2007 09:38:16
Forgot to tell you it's a three wheel tractor.
Thanks, Jeff.
