Type of oil in SM live Hyd. System?
Andy in Ohio
10-11-2007 13:02:22
I am putting a SM back together and was wondering what type of oil to use? It is a stage II with reservoir under the tank. Also should I add oil to the pump thru the top or will it be drawn into it without any problems? Also, how do I tell when the system is full? Thanks, Andy
glennster
10-11-2007 13:39:22
 Re: Type of oil in SM live Hyd. System? in reply to Andy in Ohio, 10-11-2007 13:02:22
i run hy-tran in mine with live pumps and belly pumps. the pump should self prime, but it wouldnt hurt to get some oil in there on the initial fire up.
