Live hyd pumps
Bryce Andreasen
10-11-2007 13:57:00
My '55 400 is having trouble. I have spool valves, reservoir is full, screen clean, but power steering will not work at all until a hyd. lever is pulled, then it works like a dream. I tested psi, and it was atleast 300 under factory. Where do i locate a new pump?
the tractor vet
10-11-2007 15:41:55
 Re: Live hyd pumps in reply to Bryce Andreasen, 10-11-2007 13:57:00
Also i have found that there is a plug that sometimes that blows out between the valves and i can not realy explain how to find it as it has been many years ago that i did the last one but it is between the valves. Had that problem with my buddys 450 many years ago.
Owen Aaland
10-11-2007 15:14:42
The pump is NOT the problem. If it were you would not have any better steering when you moved the control valves.
It sounds like you are missing or have a defective flow control valve. Is this a factory installed power steering or added later? If added later, you also need to change the flow control valve to one that includes a priority valve to make sure that the steering gets priority over the control valves. Without a priority valve you will have the condition you are describing.
