M water in the oil?
pete_5959
10-11-2007 17:45:38
Looked at a decent M today. Has water in the oil. Owner says he changed oil and ran it down the road and back and water was back in the oil. Checked radiator and no oil migrating to it. Any help greatly appreciated,,
Pete
Mike Farmer
10-17-2007 06:16:25
 Re: M water in the oil? in reply to pete_5959, 10-11-2007 17:45:38
One of three. Head Gasket. Cracked head. Head is warped. ( These may be considered but extremely unlikely. Cracked block internally. Incidently altho its very rare with a head gasket damaged just at the top of the liner water can get forced down past the liner. Basically if theres room for grease to help assembly theres room for water)
dej(jed)
10-12-2007 12:03:51
For all the longer it takes, pull the head and take a look. M's aren't like AC's. the heads and blocks aren't all that weak. I will bet it is a head gasket.
slowfolk
10-12-2007 05:39:59
Could be bad o-rings around the piston sleeves.
Janicholson
10-12-2007 08:46:31
 Re: M water in the oil? in reply to slowfolk, 10-12-2007 05:39:59
Sorry the M has dry sleeves. JimN
james rumph
10-11-2007 18:18:38
Almost all "M" heads are cracked in the combustion chamber down to the valve seat . My 8060 [casting # ] head was repaired in 6 places and still leaked . Anti freeze will kill motor bearings !!!!
I bought a 450 gas head that was fresh and magna fluxed [ no cracks ] . Not all cracked heads leak , there are plenty of people on here that have told that story .
I bought my 450 head thru Waynes Repair.
www.waynesrepair.com.
