1945 Farmall A Positive Ground?
Glenn C
10-11-2007 20:56:45
I just bought a Farmall A. It"s serial number identifies it as having been built later in the year 1945. The person I bought it from indicated that it uses a positive ground, rather than the traditonal negative ground. I want to confirm this before I start connecting the the cables. Thanks, Glenn.
Red Dave
10-12-2007 05:13:13
 Re: 1945 Farmall A Positive Ground? in reply to Glenn C, 10-11-2007 20:56:45
That tractor was positive ground from the factory. That was "the traditonal" in that era.
old
10-11-2007 21:40:23
ALL brands of tractors and most car used + ground till in the mid to late 50s. SO yes it is or should be + ground unless it has an alternator on it and then it would be - ground, I.E. 12 volt system with an alternator
