886 Light Problem
Lance_MF_180
10-12-2007 11:21:29
I know it is not antique, but I thought I would post the question here. We have an 886 that when we use the lights they will work for about 5 or 10 minutes, shut off, then about 2 minutes later they come back without ever having to touch the switch. I am thinking there is a bad relay, but not sure where to even start looking. Any ideas?
Thanks
Lance
the tractor vet
10-12-2007 16:11:33
 Re: 886 Light Problem in reply to Lance_MF_180, 10-12-2007 11:21:29
I would start with the lite switch and check all the connections on it then work back to the source of the feed . Sounds like a loose wire to me .
Steven f/AZ
10-12-2007 11:53:41
I know on our 1086 the relays and fuses/breakers are under the steering column - if that helps.
I also know that I"ve had to clean up the connections a few times to keep the lights working, as well.
todd hamilton
10-13-2007 08:05:42
 Re: 886 Light Problem in reply to Steven f/AZ, 10-12-2007 11:53:41
We have had same trouble on 886 - for 29 years! We have found it handy to leave the panel cover off so that you can get to the fuses and connectors (tractor has cab on it so no problem with getting wet).
