Farmall C engine runs rough
dougie94
10-12-2007 15:02:24
I have a 49 C with a mag.I just had the carb redone by Dennys,it will start up when cold and the runs decent.When it starts too warm up it begins to sputter like it's on 3 cyl.When you let the clutch out in ahigh gear it sometimes coughs and dies"govener"?But the biggest problem is it does smoke some"blue" and when i shut it off and try to restart it won't unless i clean the plugs.If I fouled the plugs once will they just keep doing it?
rustyfarmall
10-13-2007 08:03:00
 Re: Farmall C engine runs rough in reply to dougie94, 10-12-2007 15:02:24
You might want to search the forum archives for "Denny's"
don g
10-13-2007 07:15:25
my super c did same thing and it turned out to be a bad coil
ddg
10-13-2007 06:57:36
Might have stuck rings. Hook it up to your plow work it hard all day & see if that cleans it out. Might try dumping a couple of cap fulls of Sea Foam or Marvel Mystery oil into the spark plug holes after you shut it off. Let that stuff soak in & work for a few hours, & run it some more. Then check the compression again.
gene bender
10-13-2007 02:13:25
First thing always is run a compression check.
Peabody
10-12-2007 20:26:14
Check the float in the carb. Might not be adjusted right, or have a leak in it.
old
10-12-2007 17:06:11
Sounds like you need to try hotter plugs in it. Yes if you foul a plug out and then clean it they will foul out again. Sounds like it may need a rebuild on the engine if its fouling them as fast as it sounds like it does
Andrew Z
10-12-2007 15:08:00
Sounds like a coil or condensor has gone bad. When the tractor does this see if it still has spark. if not then there lies the problem. I would start with that first.
Andrew
