Starter parts for A
Soundman
10-13-2007 17:54:29
Does anyone have the bruch end casting for an A starter? It seems that the previous owner worked on the starter and did not line up the pin with the steel body of the starter and warped the aluminum casting. When the starter began to drag, I found the damage which caused one of the bruch brackets to wear and break. Everything appears in good shape. I now have the starter off my C installed while I try to start the A.
Brownie450
10-14-2007 16:30:49
 Re: Starter parts for A in reply to Soundman, 10-13-2007 17:54:29
Looked in the U123 book & the commutator end / brush-holder number from IH is 1881627. Probably no-one will have it in stock anymore. A good srarter shop will have it.
Brownie450
10-14-2007 16:19:57
Try a parts yard. They will probably want to sell you the whole starter. Is there a starter/ generator shop nearby? They should have the parts available. Does the starter have the Delco numbers on the i.d. tag & are they legible? Helps if you have them for parts.
