Farmall M Rod bearing Part #
MJF
10-14-2007 12:41:32
I'm having a little trouble with my rebuild and was hoping someone could help me out. I believe I may have gotten 450 bearings instead of M bearings Heres the rod bearing numbers RP-356958R11 and CLE 060703. These are Rod bearing that are .030 and are Clevite bearings from red power. I would also like to know what the part numbers for Farmall M and 450 Main Bearing that are .020. Thanks Mike
Mike Farmer
10-16-2007 10:58:52
 Re: Farmall M Rod bearing Part # in reply to MJF, 10-14-2007 12:41:32
Give Frank a ring or Email at Joe's Tractors its listed under Farmall on Internet. He is very knowledgeable on these issues. Mike Farmer
Owen Aaland
10-15-2007 21:21:50
You need bearings for the M. The 450 crankshaft is .050 larger than the M. You can grind a worn 450 to .050 and use standard M bearings to get more life out of them
MJF
10-15-2007 12:23:26
I had the crank to a machine shop and he said that the mains are .20 and the rods are .30 which I bought bearings for both, but when I put my crank in I have a large amount of slop. I'm hopeing that when I bought engine parts I got the rods and mains for a 450. I thinkning this because I ordered 450 pistons and sleeves and had my block bored.
Duner Wi
10-15-2007 18:58:38
 Re: Farmall M Rod bearing Part # in reply to MJF, 10-15-2007 12:23:26
All I can tell you is early M had different rod and main brgs. than the Super M,400 and 450. Could be you need the early brgs.
El Toro
10-15-2007 04:00:29
You need to contact this web site for Clevite dealer in your area. They can provide the info that are seeking. Call your local Case/IH dealer
on the .020" undersize bearings. You need to have that crankshaft measured to see which bearings are required. Your local auto machine shop can get the correct bearings. You don't want to be guessing. Hal
http://mahleclevite.com/storelocator.asp
