Stage II SH pump gear
Gauger
10-14-2007 13:53:00
I have a Stage II SH, I bought it with the hydraulic pump missing and the rebuilt one that I bought to replace it came without the drive gear. My parts book dosen't list a different gear for Stage I vs. Stage II but I think I recall reading somewhere that the live pump takes a different gear. Obviously the number of teeth would be the same, heavier maybe??
Dick fm Iowa
10-15-2007 09:50:05
 Re: Stage II SH pump gear in reply to Gauger, 10-14-2007 13:53:00
GAUGER where did you get the rebuilt hydraulic pump if I may ask? My F300 started smoking like mad while I was disking, and the Aluminum(??) pump was hto hot to touch for sure. Any suggestions are appreciated. Dick Davis
Gauger
10-15-2007 10:06:07
 Re: Stage II SH pump gear in reply to Dick fm Iowa, 10-15-2007 09:50:05
I bought the pump from a fellow from Iowa who I believe has passed away. Hi name is Les Mooi??(spelling. I'm ashamed to say that he charged me $50.00 for it although I haven't run it yet. It looks good, new seals packed with grease and ports plugged.
CNKS
10-14-2007 17:33:20
I assume you mean the cam gear. I think the upgrade occurred with the Stage 1 and possibly with the last few regular H's. The latest parts books will only show the upgraded version. If you mean the pump itself, the gears are all the same, as the distributer mounted pump only came on the Stage 2.
Gauger
10-14-2007 18:51:26
 Re: Stage II SH pump gear in reply to CNKS, 10-14-2007 17:33:20
I meant the the pump gear, on the Stage I's there is a cast iron shaft housing where the pump is on the Stage II. I took the gear off of a Stage I where it only drives the distributor, on the Stage II it drives the distributor and the pump. Didn't know if this gear is the same for I and II.
