Farmall H with JD 45 loader
Vito
10-14-2007 14:00:27
Hello,I am new to the Farmall forum.I have spent considerable time on the Oliver forum.They where a great help with my 77 project.Anyhow I have a 1951 Farmall H that I recently purchased.I have a JD 45 loader that I plan to mount on it.This is the last JD piece I have.I got rid of the JD tractors.I have a manual showing the pressure line hookup but I don't know where to run the return line to.Any help would be appreciated.
Thanks
Vito
dej(jed)
10-15-2007 05:23:48
 Re: Farmall H with JD 45 loader in reply to Vito, 10-14-2007 14:00:27
Gravity wil take care of the down. Just plumb one outlet to a Tee and then go to the bottom side of both cylinders.
chuck46
10-14-2007 20:35:55
Hi Vito, I assume you have a belly pump on your H. The front of your cylinders will increase the volume of oil. Remove the filler cap and dipstick from pump, replace it with a pipe union then a bushing to reduce to 1/2 inch pipe then a 3 inch nipple with a tee, then a nipple aimed both left and right and finish it with fittings to match your hoses. This is a common installation because the H and M did not have a large enough resovoir for two large cylinders. Good luck, Chuck
FarmallDude
10-14-2007 18:01:35
Vito: I don"t know if this will help you or not... On my 41 H, I have a Live M&W 202px pump with a #30 IH Loader.... Looking from the seat at the Control Valve... The return line comes back to the left side, right side has a (T) with the front hose looping back over to the First Hole (Towards Seat) on TOP of Control Valve.... The other hose from the (T) goes back to the Hydraulic Reservoir.
My Hydraulic Reservoir is NOT the belly pump... I have a Reservoir mounted behind the seat on the transmission cover.... The holes were already there.... Good luck and I hope this helps!
lekander883
10-14-2007 17:01:58
Not sure if this is any help but on my 45 H I have a single stage loader with a trip bucket and both of my lines ( when I'm sitting in the seat ) come out the left side of the pump. I'm not sure which is pressure and return though. I could walk out and look if that would help. Let me know.
lekander883
10-14-2007 17:29:31
 Re: Farmall H with JD 45 loader in reply to lekander883, 10-14-2007 17:01:58
I take that back. I only have one hydraulic line coming from my left side that feeds both cylinders. There is no down pressure. Operates with one hydraulic line.
