newbie to farmall 340
sailor nj
10-14-2007 16:35:18
just bought a 340 on saturday ! don't have the manuals yet { which one is best ?] where do you check hydrulic fluid level also what is the filler cap in front of the distributor for ? thanks in advance. be back later with many more questions. sailor.
Al L. in Wisc.
10-14-2007 18:54:08
 Re: newbie to farmall 340 in reply to sailor nj, 10-14-2007 16:35:18
I have a Farmall 340 w/factory utility wide front w/o power steering. I really like the styling of the 240/340/460/560 and the older 140. I have the operators, parts and IT manuals. Operators gives good info, specs and views w/locations of the types of stuff you are asking about. The archive area of this great board has a wealth of information and you can search the photo archives for tractors and implements. What are the genetic traits of the 340 you acquired? I'm sure you will enjoy it. Good luck.
sailor nj
10-14-2007 19:52:03
 Re: newbie to farmall 340 in reply to Al L. in Wisc., 10-14-2007 18:54:08
uhh, genetic traits ?????
Al L. in Wisc.
10-15-2007 19:22:30
 Re: newbie to farmall 340 in reply to sailor nj, 10-14-2007 19:52:03
Ya know der den, row crop or wide front/factory or not; power steering; two or three point; fender-less; red or yellow -if it had a government job, etc.
J.J. from Afton
10-14-2007 17:21:09
The filler cap in front of the distributor is for filling the engine oil. As for checking transmission oil levels There is flathead machine screw under the fooplate on the clutch side. (At least thats where it is on the 340 Utilitys) And the fill hoole fot the trans is on top of the platform in front of the seat. It is a large plug that has I believe 1/2 square hole in the top of it.
ny bill
10-14-2007 18:50:56
 Re: newbie to farmall 340 in reply to J.J. from Afton, 10-14-2007 17:21:09
actually its a 3/4" square hole in the plug. just to the left of the gearshift.
sailor nj
10-14-2007 18:58:58
 Re: newbie to farmall 340 in reply to ny bill, 10-14-2007 18:50:56
so then i fill thru where the plug is next to the shifter ? no dipstick ? fill to level where screw is under foot plate? [JJ's post} thanks again . sailor
J.J. from Afton
10-14-2007 19:20:26
 Re: newbie to farmall 340 in reply to sailor nj, 10-14-2007 18:58:58
Yah thats pretty much it, you take that machine screw out, than fill till the oil starts to run out there, than put it and the fill plug back in back in.
Al L. in Wisc.
10-14-2007 19:18:51
Yup.
