ih3414
bushmaster
10-14-2007 16:54:04
can anybody give me some info on a ih3414 tlb, thinking of buying one and wonder how they are for working around the yard,and durability,seems like trans and rear parts are hard to find thanks
bushmaster
10-16-2007 13:06:04
 Re: ih3414 in reply to bushmaster, 10-14-2007 16:54:04
thanks. looking at one and it cant be started the guy lifted something to heavy andpulled both bucket tilt cylinder shafts out of the tubes guy says if he starts it hyd fluid will blow out all over.guy tells me everthing works fine otherwise.he is asking 2000 for it but im a little worried about the rest of it. i see that a hyd pump and deisel injector pump go for around a thousand dollers each and trans and rear end parts are scarce and very expensive. was looking for some experienced sugestions if i should buy and hope for the best or walk away. thanks again
oh whats the weight of this machine with loader and backhoe? i see many diffrent #s 10,000 lbs-8000 lbs.. any 1 know?
Fromjb2
10-15-2007 19:33:10
Re 3414, farm model was B414 then 434,444,384 and industrial 3444.
JimB
OneWelder
10-15-2007 18:56:42
My Father bought one new - I still own and use it almost daily. Generally its used for light work ,but not always and we really have had no problems since it was new.
As far as parts go, no real problems so far- but have not needed much so far
3414 is the industrial model # there is also a farm version but i do not know model # - might be 22xx or 23xx something
