Order Farmall Cub Parts Online
Farmall Cub Brake Band Replacement
Richard Kinsman
10-14-2007 19:01:36
I have a 1957 Farmall Cub (S/N 201850) and the brake bands have worn down. Unsure of how to remove and replace. Any directions would be appreciated.
Haas
10-15-2007 18:29:10
 Re: Farmall Cub Brake Band Replacement in reply to Richard Kinsman, 10-14-2007 19:01:36
You must remove the final drives to replace the brake bands. Do one side at a time, as these tractors are offset and things can get unstable if both sides final drives are off at the same time. While you have the final drives off, you might as well replace the shaft seals too. There is a shaft seal on the transmission side and also one on the final drive side. If they are leaking, oil can get on the brake bands and ruin them. On the cub, the final drives are not real heavy, so it's not too big a job.
john *.?-!.* cub owner
10-14-2007 19:38:52
 Re: Farmall Cub Brake Band Replacement in reply to Keith-OR, 10-14-2007 19:01:36
Teh finals have to be removed, after that it is pretty easy. there are 2 different type bands, one for the toggle link system, and one for the straight( had rod welded to band).
Richard Kinsman
10-18-2007 21:41:34
 Re: Farmall Cub Brake Band Replacement in reply to john *.?-!.* cub owner, 10-14-2007 19:38:52
Hate to ask...but what are The Finals and how are the Finals removed?
Thanks so much,
RK
