Wheel weights for 1256
Mark from WI
10-16-2007 18:54:32
I was wondering if the wheel weights off our 300 will fit on our 1256. If not how much would correct ones cost and how much does one weigh The ones on the 300 are one piece. How much do they weigh. Any help would be appreciated!
Steven f/AZ
10-17-2007 07:50:10
 Re: Wheel weights for 1256 in reply to Mark from WI, 10-16-2007 18:54:32
I know the 1/2 weights on our 1256 are the same as the ones I have on my H... so the holes should line up for the full weights as well.
Make sure you have a helper or two (or a cherry picker) to get those heavy beasts on!
ejr-IA.
10-16-2007 19:06:09
They will fit fine all four holes will line up.The full weights are 150 lb each.
