Farmall H for Lanse
JT
10-17-2007 06:51:50
Hey Lanse, there is an H on Ebay that is in Ohio, might be in the price range of what you are looking for. The item number is 120170243915, it is in Baltimore, Ohio. Looks to be a decent looking piece, but needs a little work, says it died when mowing with and now will not turn over. Good luck and maybe you can now have a nice little H like you want.
Jim
georgeky
10-17-2007 07:35:51
 Re: Farmall H for Lanse in reply to JT, 10-17-2007 06:51:50
Mike, you need to get you an M and park beside the H, then the H will be your small tractor.
JT
10-17-2007 07:42:57
 Re: Farmall H for Lanse in reply to georgeky, 10-17-2007 07:35:51
When my M,H, and B are all sitting together, the H looks little compared to the M, but the B looks like a garden tractor compared to the M. :) When my 4 yr old grandson wants to go for a tractor ride, and I get the H or B out, he wants to know why we cannot ride on the big tractor (the M). How do you explain to a 4 yr old that the M is as hard headed as I am and it does not want to start easy all the time.
georgeky
10-17-2007 08:18:52
 Re: Farmall H for Lanse in reply to JT, 10-17-2007 07:42:57
JT, you should see my Cub sitting beside the M. Looks like a toy. Both my old M's start right up every time. Don't matter how hot or cold. In fact come cold weather, the M's are the only thing here that I even try to start. I don't use the little ones much during the winter as they won't lift a big roll of hay.
Mike CA
10-17-2007 07:13:54
an H is small?? I guess it's all relative. It looks huge in my garage!
Steven f/AZ
10-17-2007 07:48:47
 Re: Farmall H for Lanse in reply to Mike CA, 10-17-2007 07:13:54
Yep, the H is a small tractor these days. Was the most popular size during the 40"s, but those days of small farms are long past now.
Here"s a pic of my H on the 28" IH 7200 hoe drills. I was able to move them across the yard, scratching in 2nd gear!
third party image
