Carb on Farmall H
The tinman
10-17-2007 08:49:02
DO you know whger I can by the venturi for a 1948 Farmall H carburetor (carb # 50981DB) This part is no longer available through our dealer.
Thank You
Mike CA
10-18-2007 12:09:10
 Re: Carb on Farmall H in reply to The tinman, 10-17-2007 08:49:02
www.steelwheelranch
(785) 548-7437
Mike CA
10-17-2007 14:10:16
Rusty, you would be better qualified to answer this than I... would any correct venturi work? Meaning if I pulled one out of a junk carb from a junk yard, would that work for the fellow? I'm not sure if the junk yard will let me tear one open or not, but just in case I could check.
What I mean by "any"... what if it's rusy inside, or marred in another way? Would it still work correctly?
RustyFarmall
10-17-2007 16:33:10
 Re: Carb on Farmall H in reply to Mike CA, 10-17-2007 14:10:16
Any venturi from any H carb should work, but I doubt they will let you tear one apart because without the venturi the rest of the carb is virtually worthless.
D Slater
10-17-2007 10:37:22
This place advertizes them for $25.00. 217-694-4735 central time zone. Also looked on YT site and didn't find any.
Mike CA
10-17-2007 09:50:37
RustyFarmall might be able to help you out. He's an Ebay seller. You can look him up as RustyFarmall, and look through the parts he offers. He may have it.
RustyFarmall
10-17-2007 11:50:30
 Re: Carb on Farmall H in reply to Mike CA, 10-17-2007 09:50:37
I don't have any spare venturis. I've been looking for them myself.
Dave from Texas
10-17-2007 09:28:21
Mike at Steelwheel Ranch should be able to help you.
Walter L Mabbett
10-18-2007 12:07:18
 Re: Carb on Farmall H in reply to Dave from Texas, 10-17-2007 09:28:21
Dave
Could you tell me how to get a hold of Mike at Steel Wheel Ranch.
Thanks
