404 Lift speed
JSharp
10-17-2007 09:18:19
The 3 point lift speed on my 404 seems slow. It seems to have plenty of power but it takes about 20 seconds from the full down position to full up. Anyone have a 404 and can tell me how fast theirs is? And if mine really is running slow, where would I start looking to fix the problem?
JSharp
10-17-2007 19:46:05
 Re: 404 Lift speed in reply to JSharp, 10-17-2007 09:18:19
I may have posted too soon. I added a hydraulic valve to the system this weekend and I obviously didn't get all the air purged. After working the 3 pt a lot this morning then leaving it sit all day it's much better.
About 10 seconds for full travel. Not much difference by changing engine speed or the draft control. But I imagine 10 seconds is about as good as it'll get...
jk
10-17-2007 16:58:49
check the lever on your draft control, and make sure that for "rate of action" is is not set on slow. at low idle 20 seconds is about right. the higher the engine RPM's, the faster the hitch will raise.
