560 -shifting
tlee
10-17-2007 12:10:17
got a 560 international shifting issue...it will shift easy with TA pulled back but when it is in high range shifts hard when at a stop. Only way to shift with TA forward is shift when tractor is rolling yet and hasn't come to a complete stop...Question is ....can this be corrected with a adjustment of some sort...shifts easy in low range...
farmall driver
10-17-2007 16:16:11
 Re: 560 -shifting in reply to tlee, 10-17-2007 12:10:17
pushing the clutch all the way in on a 560 should also actuate the TA. check the linkage and ajust/ correct as needed.
tlee
10-18-2007 07:02:58
 Re: 560 -shifting in reply to farmall driver, 10-17-2007 16:16:11
thanks for the info
Janicholson
10-17-2007 13:36:05
It is the first sign of a TA that needs to be adjusted. If the clutch is being pushed in all the way to the stop, it should shift either way. A manual is the only way to be sure it is adjusted correctly. Be sure to repair any worn pins or cleveces in the linkage befor adjustment. Loose pins, and augered out holes are difficult to adjust accurately. Failure to adjust will burn out components!!! JimN
Janicholson
10-17-2007 13:35:59
