140 smoking
ddtaylor
10-18-2007 08:35:36
I have a 140 that runs fine, but smokes at idle/low speed like the valve guides are leaking oil. My question is: are valve seals available? Thanks
mikicic
10-18-2007 09:55:31
 Re: 140 smoking in reply to ddtaylor, 10-18-2007 08:35:36
Valve guides will usually cause smoke on start up only. the oil will seep past the valve guide seals when sitting not being run. Smokin all the time indicates rings to me.
Janicholson
10-18-2007 09:58:26
 Re: 140 smoking in reply to mikicic, 10-18-2007 09:55:31
Putting valve seals in it, using cotton rope in the cylinders to hold the valves up for installation, costs three hours and 35 bucks. Do it. I have seen Idle high vacuum oil burning from guides on many units. JimN
chuck craig
10-19-2007 02:06:11
 Re: 140 smoking in reply to Janicholson, 10-18-2007 09:58:26
Can you use C/A to hold up valves?
Janicholson
10-19-2007 12:52:38
 Re: 140 smoking in reply to chuck craig, 10-19-2007 02:06:11
Yes, but not as easy or certain. Dropping a valve into a hole is a disaster. ROpe in the plug hole takes 15 seconds, then turn the crank to push it against the valves. Then do the service. JimN
Janicholson
10-18-2007 09:51:26
Not OEM, the perfect Circle style can be installed (best) or plane umbrella seals (OK) JimN
