steped head pistons
Pat-CT
10-18-2007 18:14:39
im going to put steped head pistons on my h but it only has flat ones now i belive so is there anything im going to have to do to get them to fit in like a diffrent head or something or will they jsut fit in
randy hall
10-18-2007 20:24:48
 Re: steped head pistons in reply to Pat-CT, 10-18-2007 18:14:39
nothing to worry about. m+w made pistons with a one inch dome for propane conversions.your quarter inch step won't bother anything.
riverbend
10-18-2007 20:05:11
Are you putting new sleeves too ? If not, you should be careful to remove the ridge, check the ring end gap and the piston clearance. If you do not have a gas head on your tractor now, one will boost the compression ratio.
Greg
