timing a H farmall
David Booth
10-18-2007 20:11:53
Witch plug is #1 and what is the firing order?
where should the Rotor be pointing if it is in time? I also need to know what plug wire goes where on the dis. cap. This is all new to me any help would be greatful. This tractor has a magento on it witch has been by passed.
FarmallDude
10-18-2007 23:45:49
 Re: timing a H farmall in reply to David Booth, 10-18-2007 20:11:53
David: Firing order 1~3~4~2 goes CLOCKWISE... # 1 wire hole on the Cap, is the first one to the right of Top Clip (Mine Is), that holds the Cap on.... Then #3~#4~#2... Mine is a 41 H, with a Magneto and a 202px M&W live pump.... Hope this helps! G@@D Luck!
Andy Motteberg
10-18-2007 21:27:34
The number 1 piston is the one closest to the front of the tractor (towards the radiator) The firing order is 1-3-4-2. When the number 1 piston is on TDC (Top Dead Center), the rotor should be pointing to the number 1 cap terminal. I cannot tell you what order the wires hook up since I'm not around my tractor right now, someone else can help you with that.
Andy.
