Can't get the pto drive dog loose
neblinc
10-19-2007 05:39:03
The drive dog in the bottom of the pic does not want to come off, it does come off counter clockwise correct?
Tried a liitle heat but still no go.
Might have to make a bigger tool, the one on the belly pump came right off with little effort at all.
Spent over an hour last night just rying to get it off :cry:
Any suggestions?
Randy
third party image
Haas
10-19-2007 18:20:18
 Re: Can't get the pto drive dog loose in reply to neblinc, 10-19-2007 05:39:03
Make a tool that fits the slot. Maybe a piece of 1/2 inch thick steel thay you weld a nut on. If you can get an impact wrench in there, use that. If not use a box end wrench and a hammer. Lock the shaft by putting the PTO in gear and then putting something on the PTO shaft to hold it from turning. I use an old PTO yoke with a bar though it.
Nebraska Cowman
10-19-2007 05:48:31
I made a handy dandy tool by welding an old bolt to a piece of key stock and use my impact wrench. Yes, it is righthand thread.
