weight of Super M-TA
J.G. See
10-19-2007 20:37:23
I need the weight of a Super M-TA. Found the weight of the Super M but not the Super M-TA. Guessing somewhere around 5800 lbs???
J.G. See
10-20-2007 19:49:52
 Re: weight of Super M-TA in reply to J.G. See, 10-19-2007 20:37:23
Thanks everyone! We are looking at buying a trailer and needed to make sure it would haul the M-TA. We could find the weight of our H but never the M-TA.
Hugh MacKay
10-20-2007 18:35:48
See how close you were, Dave has 1,400# of added weight and AK has a 300# hitch.
FarmallAK
10-20-2007 17:53:24
Mine does not have loaded tires, or wheel weights, but does have a Saginaw 3 point hitch installed and it weighs 6,100 pounds.
Dave H (MI)
10-20-2007 06:05:24
The guy who shipped ours 4-5 years back was tight on his allowances so we had to have an exact weight for him. With all fluids including loaded tires and one set of rear weights it came to 7200 pounds almost on the nose.
Hugh MacKay
10-20-2007 02:17:07
J.G.: Weight of a SMTA and SM will not be a lot different. The rear chassis will be a bit heavier but I wouldn't think more than 500# with same ballast. I don't think you are very far off at 5800#
