460 narrow front end
cbice
10-20-2007 06:37:44
Need some help ,want to put a narrow front end on my 460 will an M fit? Thanks Clif
ejr-IA.
10-20-2007 18:09:52
 Re: 460 narrow front end in reply to cbice, 10-20-2007 06:37:44
Again a M and 460 have the same pattern.A M bolster will fit ,400,450,560,656,706,806 ,756,856,1206,1256,1456.
Wardner
10-20-2007 15:24:21
I've been playing around with both a narrow and wide front today on two SM's. The narrow lower bolster has a square bolt pattern of 4.5" by 3/4" bolt holes.
D Slater
10-20-2007 13:30:17
Yes,if you use the M wheels and rims along with the M lower bolster.
CNKS
10-20-2007 14:17:53
 Re: 460 narrow front end in reply to D Slater, 10-20-2007 13:30:17
Two yes, two no so far. Averages out to "maybe". I will repharse the question to "Is the bolt pattern on the M lower bolster different from the 460?". If not then the 460 is different from the H (I think.) I have never directly compared them.
D Slater
10-20-2007 17:33:15
 Re: 460 narrow front end in reply to CNKS, 10-20-2007 14:17:53
4 bolt pattern is the same for M,560,460 and others. 460 and 560 farmall use the same front end above lower bolster. 460 frame rails widen out in front of clutch housing to same width as 560.
CNKS
10-20-2007 18:53:36
 Re: 460 narrow front end in reply to D Slater, 10-20-2007 17:33:15
Thanks
Steven f/AZ
10-20-2007 13:06:43
No.
CNKS
10-20-2007 09:03:59
Probably not, the 460 followed the H-350 series, H and M are not interchangable without modification. Whether they changed the 460 to M specs, I don't know.
ejr-IA
10-20-2007 08:50:57
Yes
