966 won;t move
Bill Ramsey
10-20-2007 08:29:18
Have a 966 that quit moving I can;t fell it move or even shake in any gear high or low ta or high low range. Can this be hyd or the clutch plumb gone. Power steering barely works. I would appreciate any help. Bill
756puller
10-21-2007 08:53:01
 Re: 966 won;t move in reply to Bill Ramsey, 10-20-2007 08:29:18
I have worked on a few IHs that would not move like what you posted more than likely you problem is in the clutch housing with the input shaft or the center of the clutch broke out
the tractor vet
10-20-2007 10:39:20
Well it vary well could be a blowen gskt and O/Ring in the MCV or ya may have stripped the splines on the IDPTO input as this is what runns the hyd. pumps and PTO and if that is gone then the tractor will not move . IF the PTO works then here with out running a couple pressure checks i can not say for sure . OR like ya said you clutch is toast .OR it even could be a twisted off input shaft going into the T/A.
