Restoring 400 Farmall
Devon
10-20-2007 13:30:39
I'm restoring a 400 and I don't know what the back of the tractor should look like. It has a fast hitch and one outlet but the gentlemen that owned it before had a loader on it so there are lines everywhere. I also need the steel lines that run across the platform from the hydraulic pump to the fast hitch. Information on either of these would be greatly appreciated.
Janicholson
10-20-2007 18:04:00
 Re: Restoring 400 Farmall in reply to Devon, 10-20-2007 13:30:39
Wardner is correct.
caseih.com then USA, then Parts and service, Then search for Parts, Then start your search here, then put in Farmall, Then go down list to 400, then hydraulic system, Fast hitch etc. Good luck, JimN
Wardner
10-20-2007 15:34:27
You need a parts book. There are about 10 different illustrations showing hydraulic lines to the rear.
