Help Farmall C guys....
Justin S. - TX
10-20-2007 14:24:34
I have a set of plows for my C that consists of a long bar that goes under the belly of my tractor and connects to two large plows. It connects to the touch contol system via a frame that bolts up by the radiator. I have looked and searched the internet and cannot find out what they are called, much less the model number. If anyone knows, I would greatly appreciate it if you would let me know. Thanks alot.
Mike Cacic
10-23-2007 17:57:49
 Re: Help Farmall C guys.... in reply to Justin S. - TX, 10-20-2007 14:24:34
I have the same plow that I have had it on but needs new points and moldboards are thin. These were equiped with plow chief independent points which I don't know if you can get anymore but should beable to use current 14" plow shares which have the points on them. Mounting this plow is not fun but can be done with relatively little pain. The biggest trick is lining up the bracket that bolts on to both sides of the torque tube under the battery box. I did by myself but two people make it very easy. I have cultivators for mine and it is a nice little tractor to cultivate with the touch control.
davejoe
10-20-2007 20:24:52
If it is a non fast hitch, model C-295A I have most of an owners manual. If you need some copies I can E-mail some. Dave
Justin S. - TX
10-21-2007 05:40:52
 Re: Help Farmall C guys.... in reply to davejoe, 10-20-2007 20:24:52
It is not a fast hitch. If you could email, that would be great. Rabduck03@hotmail.com. Thanks.
Justin S. - TX
10-21-2007 15:51:15
 Re: Help Farmall C guys.... in reply to Justin S. - TX, 10-21-2007 05:40:52
I looked online at the A-295A plow, if the C-295A is similar this is not the right plow. This set of plows hangs on a 2" square steel bar that is mounted to some lift frames. This whole assembly is right underneath the motor/clutch housing.
