M Low Speed 1st Gear
Jim J
10-20-2007 19:15:13
I found a low speed 1st gear set up for an early M today in a M inthe salvage yard. I have the cover pulled and it looks to be in good shape. What is it worth?
Wardner
10-20-2007 19:36:24
 Re: M Low Speed 1st Gear in reply to Jim J, 10-20-2007 19:15:13
I guess it depends on how bad you want it and who goes to the trouble of getting it out of the tractor.
I sell for high prices and expect to pay high when I find something I want. If it was in my barn, I would probably want $400-500. It is not run of the mill stuff. Stock antique pullers want them. Check "completed" listings at eBay. A set or two may have changed hands in the last month.
You need:
the main shaft first gear
reverse idler cluster gear
second gear on countershaft
countershaft with integral first gear
Jim J
10-20-2007 19:44:36
 Re: M Low Speed 1st Gear in reply to Wardner, 10-20-2007 19:36:24
I have it out of the tractor. All of the gears are in good shape. The only problem I see is that is for an early M with the dog style PTO. It did Have the adapter to change over to the spline type PTO.
