Low gears
N.D. Farmall H
10-21-2007 20:47:33
I bought a H with the serial # ending with XIL which according to the Farmall serial # makes this tractor a low gear tractor. I have seen serial # ending in XIN which makes this tractor a low low gear tractor. I was wondering if there is a difference between the two gears speeds.
CNKS
10-22-2007 06:59:54
 Re: Low gears in reply to N.D. Farmall H Puller, 10-21-2007 20:47:33
D Slater is correct, as is georgeky. Small clarification, low and low low are the same, that is there is only one set of low speed gears.
10-22-2007 06:48:50
So what kind of value do you think this kind of tractor has?
CNKS
10-22-2007 07:02:34
 Re: Low gears in reply to N.D. Farmall H Puller, 10-22-2007 06:48:50
I don't really know. A guess is to add $500 to what a normal geared tractor would bring. Makes a $1500 tractor worth $2000. This is only my way of thinking, which is often wrong.
D Slater
10-22-2007 05:08:09
X1N is everything George said about X1L with the only differance being the X1N originaly was 8000 foot equiped.
georgeky
10-21-2007 22:17:16
My chart don't show an N in the suffixes. It does show that X1L is for 5000 foot pistons, 7 mpg 4th gear and low low gear. It is fairly rare arrangement.
