handy dandy m
glennster
10-22-2007 07:36:51
heres some pics of my 52 m. she's a hard worker and a handy tractor. has wide front, char-lynn power steering, char-lynn two way hydraulic kit, saginaw 3 point, m+w 9 speed, lambert disc brakes, and a haddican bros 250 amp dc welder that runs off the belt pulley. (got firecraters in er too). 12volt conversion. aint stock, aint origional, but when things go wrong, thats the tractor to go git!!!!
third party image
third party image
third party image
third party image
Andy Motteberg
10-22-2007 22:45:25
 Re: handy dandy m in reply to glennster, 10-22-2007 07:36:51
Nice M
Buck E
10-22-2007 16:31:58
Welder won't work off pto. Not enough rpms. I hooked a 110 ac generater on H with 8in. sproket and no juice.Might work off belt pully because speed is approx. 2600 rpms against about 560 on pto. Nice set up on the M. Buck E
D Slater
10-22-2007 09:39:05
Can't say for sure without looking at tractor, but in picture it looks to me like regular IH type disc brakes. If tractor is a high enough serial # 1952 model they would be original.
Janicholson
10-22-2007 12:02:20
 Re: handy dandy m in reply to D Slater, 10-22-2007 09:39:05
You are correct, My dad was under the impression that all disk brakes were Osco-Lambert. Thanks to an old engineer from IH that I discussed it with (he was on tha brake design team sorry to say) I was corrected. JimN
aaachris
10-22-2007 07:52:07
I like the welder you have on there. I have a SH and a 180 amp Lincoln welder with a bad wisconsin engine. I was thinking about rigging it up like you have, but it's not going to fit because of the loader. Wonder if I can run the welder off the rear pto.
glennster
10-22-2007 18:25:55
 Re: handy dandy m in reply to aaachris, 10-22-2007 07:52:07
see how many rpm the generator runs at. you could belt the welder up to the pto to increase the rpm as necessary. big pulley on the pto to a small pulley on the welder.
