350U T/A Question
Todd in NC
10-22-2007 15:00:57
I"ve asked this question before, but its been four years. I bought a rebuilt sprague T/A from Steel Wheel Ranch to go in my 350U. I"ve got a I&T shop manual that tells how to replace it but it seems pretty vague. Once I get in there, is it pretty self explanatory? One out one in situation? Splitting the tractor is not a problem. I"ve been there done that many times, just not on a number series. Also, I was told that sometimes you get one that needs to be shimmed (like one out of a hundred). Anything to this? I"m going to start on it this weekend, so I"m sure I"ll have more questions before I"m through. I had pretty much given up on it until a man that I work with said he has a place and equipment to work on it with. So I thought I"d give it a shot. Thanks, Todd.
Kevin Meier
10-22-2007 18:21:10
 Re: 350U T/A Question in reply to Todd in NC, 10-22-2007 15:00:57
The t/a"s that I build are core except for the heavy duty version with a modified ramp. Some of those need shimmed but I"ve never heard of a standard oem t/a needing anything.
Kevin
Joe Evans
10-23-2007 06:55:05
 Re: 350U T/A Question in reply to Kevin Meier, 10-22-2007 18:21:10
Kevin,drop me an email about your TA work. I need to know some things about an article I'm doing.
Thanks
jevans@midohiomechanical.com
russ hamm
10-22-2007 15:17:24
I also have a 350u with a t/a problem. I have to hold the lever back to make it work. Is that just an adjustment problem? Saw the post and didn't mean to horn in.
Kevin Meier
10-22-2007 18:22:59
 Re: 350U T/A Question in reply to russ hamm, 10-22-2007 15:17:24
As long as the t/a works while you are holding it back it's probably an adjustment problem.
