steering column seal
tom nj
10-23-2007 15:51:34
Hey guys I pulled out the lip seal in my 300 utility steering column this weekend that was leaking. It is a 1 5/16" OD and 7/8" ID, I have been to 3 bearing and seal suppliers and none of them has this seal. Anyone out there have any ideas where I can possibly find one? I also checked MCMaster. It doesn't match up with a metric seal either,tried that.
Janicholson
10-23-2007 18:34:49
 Re: steering column seal in reply to tom nj, 10-23-2007 15:51:34
The one I pulled out of a 350U had numbers, and a replacement was found at Motion Incorporated, in stock. Measuring the shaft is more important than the seal lip, (I do not know how you measured, but it is important) Keep us in the loop. JimN
Janicholson
10-23-2007 19:00:58
 Re: steering column seal in reply to Janicholson, 10-23-2007 18:34:49
I got the name wrong, Motion Industries. Here is a partial list of seals that came up with the sizes you gave:
0958119 400020449041 SEAL Available Inventory: Available P.O.R. DOWTY Item #00958116 400024449041 SEAL Available Inventory: Available P.O.R. C-R Item #01319913 40003 OIL SEAL Available Inventory: Available P.O.R. C-R Item #01319913 40003 OIL SEAL Available Inventory: Available P.O.R. C-R Item #00613762 400030 V - RING Available Inventory: In Stock $3.72 DOWTY Item #00958122 400032449041 SEAL Available Inventory: Available P.O.R. C-R Item #01281084 400034 V - RING Available Inventory: Available $13.51 C-R Item #00613764 400040 V - RING Available Inventory: Available $5.66 C-R Item #01281112 400044 V - RING Available Inventory: Available $10.42 C-R Item #00613766 400050 V - RING Available Inventory: Available $8.28 ROBOTIC PROD Item #02620457 400050-875 SEAL Available Inventory: Available P.O.R. C-R Item #01281136 400051 V - RING Available Inventory: Available $8.28 C-R Item #01281145 400054 V - RING Available Inventory: Available $13.51 C-R Item #01281154 400055 V - RING Available Inventory: Available $13.51 C-R Item #01335928 4000550 OIL SEAL Available Inventory:
JimN
tom nj
10-23-2007 19:21:33
 Re: steering column seal in reply to Janicholson, 10-23-2007 19:00:58
Jim, What a find! I went to their web site and was like a kid in a candy store! I may smooth out the shaft a few thousands and get a seal a little undersized. This is great, thank you, thank you!! Let you know how it works out. Tom
