wont run
BIGFUTTY
10-24-2007 14:35:30
I had my farmall c running but it wouldnt idle down. found out that the sleeve and bearing needed replaced in the govener. now when i try to start it it back fires threw the exhaust. i was wondering what you think i did wrong or what needs fixed.
El Toro
10-25-2007 07:10:23
 Re: wont run in reply to BIGFUTTY, 10-24-2007 14:35:30
third party image
This is for a B, but a C should be similar. I have it for a Super C if you need it. Note how the punch marks are aligned. Hal
gene bender
10-25-2007 04:54:38
You must have moved the gear need to take gov housing off again and look for the timing marks on the gear and cam they will be hard to see and you mite want a I@T manual as it will show the timing dots and how they should be. You will need a little mirror to see them with the gov housing off.
Red Dave
10-24-2007 15:10:55
Did you remove the gear that the flyballs are mounted in?
If so, you may have put it back in wrong. It must go in the exact same tooth it came out of.
Janicholson
10-24-2007 16:09:49
 Re: wont run in reply to Red Dave, 10-24-2007 15:10:55
That is likely the answer. Putting it back will be a bit of effort. Pull #1 plug. Rotate the engine till air pushes out your thumb stuck in the hole. Put a piece of stiff vinyl covered wire in the plug hole and rotate till it is at the very top. Set the timing mark (hole in cover at flywheel) to TDC
Timing marks should be on gear in hole, and gear on governor. If not set the rotor to point to 1:30 (looking forward). Good luck, JimN
El Toro
10-24-2007 15:07:48
Are you sure your plug wires are in the correct firing order? Should be in this order. Hal
2-1
4-3
