? about 1206 no start
Alvin NE WI
10-24-2007 17:19:33
I got a 1206 that hasn't run for about 3 years, mainly because the batteries went north. Put some new ones in and now i can't get it to start, have smoke coming but no pop. The fuel is the same as when i stopped it. Would the diesel get old so it wouldn't fire up? Any help appreciated.
Alvin
karl f
10-25-2007 16:19:13
 Re: ? about 1206 no start in reply to Alvin NE WI, 10-24-2007 17:19:33
change the fuel filters too.
remember the throttle is the stop switch, needs to be about midway to ensure the fuel delivery gets to the injectors.
how are the air filters? 3 years is enough time for squirrels and other rodents to pack them full of stuff and block the air intake.
karl f
minnesota red
10-24-2007 18:39:00
give it a sniff of ether,the fuel probably does not have enough cetane to get the old girl to light up.
i would also dump a quart of auto tranny fluid in the fuel tank to clean the injectors back up.
El Toro
10-24-2007 17:23:08
You probably need to bleed the fuel system. Hal
