International 424 clutch problems
Gary Fitzwater
10-24-2007 18:37:18
I am having problems with a clutch. If I start in neutral it will grind when shifting. I have replaced the pressure plate, clutch plate,and T.O. bearing. If I start it in gear it shifts fine. Not sure if it is an adjustment problem or what.
Fromjb2
10-25-2007 21:32:29
 Re: International 424 clutch problems in reply to Gary Fitzwater, 10-24-2007 18:37:18
Gary, probably require fingers on pressure plate to be adjusted. Search achives under 444 or 434, someone posted instructions about a couple months ago to adjust fingers.
JimB
Doc Larry
10-25-2007 05:31:06
Did you check your pilot bearing?
Larry
Gary Fitzwater
10-25-2007 17:31:28
 Re: International 424 clutch problems in reply to Doc Larry, 10-25-2007 05:31:06
Yes,I forgot to mention that I replaced it also.
IH2444
10-24-2007 19:22:30
Is this a 2 stage clutch ? If so it is probably not set up/adjusted right.
Gary Fitzwater
10-25-2007 17:34:31
 Re: International 424 clutch problems in reply to IH2444, 10-24-2007 19:22:30
Yes,it is a 2 stage. Would this adjustment problem be in the pressure plate?
