Farmall H belt pulley
Scott Rukke
10-24-2007 21:19:04
I recently bought a belt pulley for my H which currently doesn't have one installed and am wondering if there is a linkage or rod that goes back to the drivers area to engage the pulley. If so does anyone have a picture or diagram so that I can see what it looks like and how it's mounted?
Mike CA
10-25-2007 20:29:00
 Re: Farmall H belt pulley in reply to Scott Rukke, 10-24-2007 21:19:04
Allan Lance said: what is that red control lever, or is it a crank maybe, above the belt pulley engagement lever?
That is the radiator shutter control. As you can see mine is bent and doesn't turn. I haven't tried to straighten it yet.
Rootsy
10-25-2007 08:40:16
Scott Rukke said: (quoted from post at 21:19:04 10/24/07) I recently bought a belt pulley for my H which currently doesn't have one installed and am wondering if there is a linkage or rod that goes back to the drivers area to engage the pulley. If so does anyone have a picture or diagram so that I can see what it looks like and how it's mounted?
or you could get a length of 1/4 inch diameter rod and break out the torch and vise and make our own. the end that gets bent over at 90 degrees gets a hole drilled through it for a cotter pin.
Mike CA
10-24-2007 21:26:25
Here is mine.
If you need the handle, and aren't in a hurry, I am heading to the junk yard probably Friday. I'll see if I can find one.
third party image
Scott Rukke
10-24-2007 21:34:36
 Re: Farmall H belt pulley in reply to Mike CA, 10-24-2007 21:26:25
Thanks for the quick response and picture. I haven't even received the gear box yet in the mail and I saw a rod on ebay so I wanted to make sure it was the right one and it is. If it doesn't pan out I'll let you know.
Allan Lance
10-25-2007 19:57:28
 Re: Farmall H belt pulley in reply to Scott Rukke, 10-24-2007 21:34:36
hey guys, what is that red control lever or is it a crank maybe above the belt pulley engagement lever? My McCormick W-6 has one two, it look slike it has something to do with the governor? Just curious, thanks in advance
brainerd dave
10-25-2007 22:09:45
 Re: Farmall H belt pulley in reply to Allan Lance, 10-25-2007 19:57:28
Allan,
That's the crank to open and close the radiator shutters.
Bob Kerr
10-24-2007 22:43:13
IH has the gasket for the belt pulley. If you don"t get one from IH be sure you get one the right thickness so the gears mesh right or it could get noisy. By the way , my 51 H has the same rod as Mikes.
Scott Rukke
10-25-2007 07:54:03
 Re: Farmall H belt pulley in reply to Bob Kerr, 10-24-2007 22:43:13
Good point. Thanks. Can you tell me where to get one? Can't seem to find one searching the internet.
