Farmall M Carb Needle leak
Zach Bouchard
10-25-2007 13:27:07
The needle on my Farmall M carb is dripping. Will the Yesterdays tractor carb kits come with the parts to fix it? If not what can i do to get it to stop?
John in Ct
10-25-2007 18:21:04
 Re: Farmall M Carb Needle leak in reply to Zach Bouchard, 10-25-2007 13:27:07
I had the same problem on my H. Long story short, I put a new IH needle, seat, washer and float in it and it works fine!!
Wayne in MN
10-25-2007 13:43:21
Which "needle"? The high speed mixture screw on the bottom of the carb or the needle & seat inside the carb??
The high speed mixture screw packing can be tightened and/or replaced.
The needle & seat leakage: 1. replace them if old & worn or 2. shut off the gas tank, remove the drain screw so the carb float bowl will empty, leave the plug out & run some gas thru the carb, shut off the jgas tank, replace the plug & turn on the gas at the tank. This "flushes" minute particles out of the needle seat and allows full closure of the needle.
