H oil pan size
Mike CA
10-25-2007 20:40:54
Here is what I am assuming. The oil pan from an H and a Super H are the same thing. Right?
What about from a 300? Same size?
CGtractor
10-26-2007 09:13:46
 Re: H oil pan size in reply to Mike CA, 10-25-2007 20:40:54
Not all 300's have dipsticks. I have a 300 engine and the pan looks just like the one on my H.
Mike CA
10-26-2007 08:02:33
Well that's a bummer. So much for that idea I guess. third party image
D Slater
10-26-2007 16:25:32
 Re: H oil pan size in reply to Mike CA, 10-26-2007 08:02:33
Oil pans I know about. H tractors with a pipe plug for drain and openings for petcocks. Later H and super H,drain plug changed to fine threads with sealing washer. 1 1/8 wrench fits head. Plug used on 300 and 350 also. Early farmall 300 tractors the oil pan same as SH.Later 300, all utility and 350 used a pan without petcock openings unless they were distillate or kerosene tractors, then they had both petcock openings but only the bottom one had a petcock. Later IH replacement oil pan for H through 350 had all the openings and what openings wern't needed were pluged.
Andy Motteberg
10-25-2007 20:45:18
Farmall 300's have a oil check dipstick in the block, so most 300's don't have oil check plugs in the oil pan, you need check plugs on a H.
Mike CA
10-25-2007 20:42:02
Oh, and I'm assuming a 330U is the same engine, so if a pan from a 300 works on an H, a 300U will as well?
CNKS
10-26-2007 17:39:42
 Re: H oil pan size in reply to Mike CA, 10-25-2007 20:42:02
330? No, the 330 was essentially a 350 with a C135 engine, along with other modifications. The C135 is the successor to the C113/C123 used in the A,B,C, etc--same configuration. My understanding is that the 330 was brought out because IH was not quite ready to introduce the 340, a more "modern" tractor than the 350, the 340 also used the C135. Don't even think about that pan.
CNKS
10-26-2007 17:41:59
 Re: H oil pan size in reply to CNKS, 10-26-2007 17:39:42
If the 330 was a typo, yes the 300 row crop and the 300U use the same pan.
