Success story to share
SproutW
10-26-2007 20:47:15
Very happy that I finally got my F-20 engine fired up after working on it for three long years. Wanted to thank everyone for all of help and I've attached a video for you guys to enjoy. Now I just have to finish the rest of it. Thanks again.
http://s168.photobucket.com/albums/u200/SproutW/?action=view¤t=Picture856.flv
the Unforgiven
10-27-2007 14:24:05
 Re: Success story to share in reply to SproutW, 10-26-2007 20:47:15
Cool! Were you the guy with the high-top pistons?
SproutW
10-27-2007 15:22:36
 Re: Success story to share in reply to the Unforgiven, 10-27-2007 14:24:05
Yup, that's me. It's been a long road but so far everything has worked out. You F-20 guys got the Mag advance down pat? I noticed when I messed with the mag advance rod the engine would rattle or slightly knock if I advanced the mag all the way during idle. I'm guessing that would be some pre-ignition? Any guidance, don't want to ruin my new motor!!!
the Unforgiven
10-27-2007 16:29:08
 Re: Success story to share in reply to SproutW, 10-27-2007 15:22:36
If your are timed right to start with full advance should only been used when you have the engine wound up and loaded. If you speed the engine up a little and advance the spark it will reach a point where it will start to run a little "fluffy", I back up a little and leave it there for general fooling around.
SproutW
10-27-2007 06:50:58
I'm not sure what the rod bolts were torqued to. I actually had my machine shop install the rods and mess with the babbitt bearings. Something I was worried I was going to screw up. Everything else besides turning the crank and rebuilding the head I did.
STEWARTINPA
10-27-2007 02:18:09
THATS GREAT I HAVE BEEN WORKING ON MINE FOR 2 YEARS AND I BET 2 MORE UNTILL IT IS DONE. WHAT DID YOU TORK THE ROD BOLTS TO? THANKS STEWART
Andy Motteberg
10-26-2007 22:04:21
I saw your photos, but my stupid dial up internet won't load the video. I'll bet it runs great though!
Good luck finishing it and glad to hear you got it running!
Andy.
