hydraulic lines
carlton
10-26-2007 21:40:14
I have a farmall 300 row crop and have a leak ,it looks like a hairline crack all around,on the supply side. CAn this be repaired?I took it off and cleaned all the brazing off.if it ccan't does anyone know where I can find another line?
Carl
clancy Mt
K.B.-826
10-27-2007 15:55:09
 Re: hydraulic lines in reply to carlton, 10-26-2007 21:40:14
As long as it's not rusted, it's fixable. Any farm equipment or welding shop could braze it. Very common repair, I bet 99% of all tractors over 30 years old have a brazed line somewhere.
Janicholson
10-27-2007 06:39:18
Yes it can. a good welding shop can braze weld the component back together, or reinforce it if the line is cracked through. If a replacement is hard to find, get an estimate. JimN
bob ia
10-27-2007 05:58:11
mthere are shops that make them up. here it is HOse and ends. they have most fittings and can bend pipe .only problem is would need old one for pattern
Dave S.
10-27-2007 04:22:47
Call Stauffer Salvage Ph # 785-966-2739. I bought the engine out of a 300 they had setting in the yard and they might still have the lines.
