Replacing fanbelt on F-14
migraine
10-27-2007 10:08:34
While warming up the F-14 last evening the fanbelt broke. Looked pretty rotten so off to get a new one. Can I get that thing between the hand crank insert notches and the bottom pulley. I know I can get it over the fan and on the top but the bottom looks pretty tight. Thanks Migraine
Dave Allgire
10-28-2007 10:11:12
 Re: Replacing fanbelt on F-14 in reply to migraine, 10-27-2007 10:08:34
From personal experience, it is much easier to remove the two bolts holding the crank bearing in place and shoving it toward the front. That leaves plenty of room to put the new belt on the crankshaft pulley. Just don't overtighten the new belt and check it again after a few hours of run time.
Andy Motteberg
10-27-2007 14:19:59
Yes,you can get it in there, but it might be a little tough.
Athol Carr
10-27-2007 13:06:46
On an O-12 one has to loosen the two bolts holding the hand-crank to the front frame to get the belt over the crank pulley, even then there is little room to get ones hands in.
not sure
10-27-2007 11:56:01
I'm not 100% positive if you can or not. But if you can't there is only 2 bolts that hold the hand crank shaft to the front bracket if I remember right. Once those two bolts are out just slide it front and you will have plenty of room.
migraine
10-28-2007 15:46:51
 Re: Replacing fanbelt on F-14 in reply to not sure, 10-27-2007 11:56:01
Thanks guys. CaseI.H. dealer was closed for the week and 3 parts places did not have anything close. Does anyone know the length of the belt or a number from the parts book?Thanks Migraine
Dave Allgire
10-29-2007 15:27:50
 Re: Replacing fanbelt on F-14 in reply to migraine, 10-28-2007 15:46:51
Part # 28593-D from Rice Equipment in Clarion, PA. $10.85 + shipping. Phone #814-226-9200
