Farmall H Loader
Martin Miller
10-27-2007 15:29:39
I was wondering if a loader that came off from a Farmall 300 row crop will mount right up to an H? Also the bucket is hydraulic but my H only has 1 way hydraulics is there a way to run those cylinders both ways? Any help would be appreciated. Thank You.
Janicholson
10-27-2007 16:44:20
 Re: Farmall H Loader in reply to Martin Miller, 10-27-2007 15:29:39
It should bolt on.
The hydro on the 300 might be 3 to 400 PSI stronger, so if the cylinders were smaller in diameter, it will be a little less on break out lift.
A two way valve can be used (many pics and discussion in the Search For box above). The existing rod will be need to be wired/held back all the time to allow the pump to run. It will not have live Hydro, (the hydraulic will stop when the clutch is in). JimN
